03-21-2005 03:44 PM
03-22-2005
06:45 AM
- last edited on
08-22-2025
06:36 PM
by
Content Cleaner
Hi MM
Unfortunately, according to the LabView Help doc, neither the "Scaling and Mapping" or "Amplitude and Level Measurements" Express VIs are included in the Base Package. 😞
I'm assuming that you are using the Getting Started with LabView manual linked here
I can't say I understand why the tutorial should reference VIs that are not included with your package, it may just be an oversight. However, generally you can workaround the Express VIs as you have done.
If you get stuck you can always post another question on the forum.
Good luck.
Neil
03-22-2005 07:46 AM
