LabView communication with Direct PLCs?
Can LabView be used to program Automation Direct PLCs (particularly DL-205)?
(4,110 Views)
_________________
Hi Derek,
LabVIEW cannot be used per-se to program the DL-205. However, LabVIEW (along with the DSC module) can be used to "monitor" the DL-205 PLC. In other words, you can read and write to all the IO in the PLC, but not program the PLC itself.
Hope this helps.
Khalid 🙂
________________
(4,110 Views)
Hi Khalid,
Thank you for the input. At least I know I could monitor existing installations. - This helps.
Thank you,
Derek.
(4,110 Views)
__________
Derek,
Just a reminder: as I said, you will need the DSC (Datalogging and Supervisory Control) Module on top of your LabVIEW for this. Actually, the DSC Module has a suite of drivers for third-party PLCs and Controllers. And DirectLogic is supported.
Good luck.
Khalid 🙂
____________
(4,110 Views)
