LabView FPGA Compile WOrker 2012 for Linux error
Hi Folks, we finally got compile worker for Linux to connect to a compile server, but when users submit jobs to the worker, they get the following errors (from a user's email). We're running Compile Worker 2012 SP1, and with the FPGA module Xilinx tools v. 13.4. Any ideas as to what might be causing this? Thanks...
I tried to compile on the Linux box. I got as far as sending the job over, and starting the plan-ahead step. That means I’m connected to the Linux worker, great progress.
Unfortunately, I soon after received fatal errors from the job, such as:
FATAL_ERROR:Portability:PortDynamicLib.c:408:1.33 - dll open of library
</opt/natinst/NIFPGA/programs/xilinx13_4/ISE/lib/lin/libTclTaskProcess.so>
failed due to libXi.so.6: cannot open shared object file: No such file or
directory. Process will terminate.
(2,583 Views)
Never mind, I think I have all the pertinent lib directories in the linker paths...
(2,559 Views)
