Enable/Disable Grid Alignment Shortcut
Am I only one who can't change default shortcut for Enable/Disable Grid Alignment Shortcut (LV 2013)? Default is Shift+Ctrl+# and I'm trying to change it for eg F5 (I have my alignment and distribution under F's - old habits from Diablo for quick actions Smiley Happy) but after pressing "set" and OK it changes back to default.
It is possible to assign shortcuts for specific type of alignment/distribution (presently it is shortcut for last used type, from what I noticed)? I'm not talking about quickdrops.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Message 1 of 9
(6,446 Views)
To tell the truth, I've never tried that. But can you not reassign the shortcut at all, or just not to F5? I have run into issues before with other programs (like MS Word) that you couldn't assign a shortcut that didn't use a modifier.
For example, I couldn't assign a shortcut to F2 but I could to shift-F2.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 9
(6,431 Views)
I don't want to use modifiers because I think it is inconvenient.
There is no problem with assigning F buttons for shortcuts. F5 works for eg broken wires cleanup. The problem is with Grid Alignment Shortcut.
Michał Bieńkowski
CLA, CTA, CPI
Message 3 of 9
(6,425 Views)
Indeed it seems that you can not give a new shortcut to the Enable/Disable Grid Alighment.
Since this is more like a feature that will help you program faster and improve the usability of LabVIEW, I suggest you to post it on ni.com/ideas and LV programmers will vote it.
The ideas that will have the most votes will be implemented in the future versions of LabVIEW.
IR.
Message 4 of 9
(6,367 Views)
Message 5 of 9
(6,366 Views)
Don't You think that reporting Corrective Action Request will be better? After all, option for changing Enable/Disable Grid Alignment Shortcut is already in LabVIEW but does not work Smiley Sad
Michał Bieńkowski
CLA, CTA, CPI
Message 6 of 9
(6,358 Views)
Accepted by topic author bienieck
Hi Bienieck,
You are right, I am sorry for that.
I have filed the CAR for that.
IR
Message 7 of 9
(6,339 Views)
Thanks IonR, by the way, how to report CAR?
Michał Bieńkowski
CLA, CTA, CPI
Message 8 of 9
(6,326 Views)
Basically it can be done only by National Instruments engineers.
The issue has to be reproduced on multiple computers and in the latest version of the software.
In case you find other unexpected behaviors please contact National Instruments technical support and report that. Basically, if it is a showstopper, you can also work with the applications engineers to receive a work around for the issue.
Let me know if you need more information about that.
IR
Message 9 of 9
(6,323 Views)
