LabVIEW proverbs!
Quote Coq Rouge:
Using Express VIs is like peeing in your pants a cold winter day. You may get warmer for a few minutes. But after that it will be very cold.
http://forums.ni.com/ni/board/message?board.id=170&message.id=484100#M484100
Message 191 of 305
(4,790 Views)
Ben quoted:
"If in doubt, rich-click" R. Brueggman (LV Basics I June 1999)
Was the ''rich-click'' on purpose? Shouldn't it be ''right-click''? I prefer to clear my doubts with just one click.... right and left clicks confuse my mind.
Here a general social club statement as a contribution to this thread:
''I hate endless tampering with thoughtlessly overloaded products'' (found on info-labview on the 20th of April 2010)
PS: Info-labview is an excellent resource of down to earth professional advice for LabVIEW programming and it has this charming flair of a small cozy social club too.
Happy wireworks
Urs
Message 192 of 305
(4,691 Views)
"Once you go down the path of the dark side (sequence structure), forever will it change your destiny."   by Tbob
http://forums.ni.com/ni/board/message?board.id=170&thread.id=499324&view=by_date_ascending&page=2
Felix
Message 193 of 305
(4,610 Views)
"Excellence will never be standardized, only mediocrity.  Cast off the shackles of the style guide, strive for excellent code and eventually today's excellence will be tomorrow's standard. " by Darin.K in this thread.
Ben
Message 194 of 305
(4,513 Views)
Here's the thread Ben referenced.
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
Message 195 of 305
(4,447 Views)
NI version calculator
Message 196 of 305
(4,434 Views)
Do you mean when we "press" for a reason the entire process stops?:smileyvery-happy:
Message 197 of 305
(4,389 Views)
I think everything should be inside the loop. As long as NI needs to increase revenue, a new version of LabVIEW will exist. When Reason stops, no new versions. I think the versioning is broken though; it doesn't take into consideration point releases 😄
Message Edited by Phillip Brooks on 06-16-2010 06:26 AM
Message 198 of 305
(4,370 Views)
The above VersionCALCULATOR (tm) is still in closed beta.  It is designed to run on older systems and so doesn't update the version number in real time nor allow for dynamic revenue adjustment (DRA).  Your concerns will be addressed in the next version, but only if they can be replicated.
Message 199 of 305
(4,335 Views)
as seen here
Sometimes a wire isn't the solution.
"Should be" isn't "Is" -Jay
Message 200 of 305
(4,141 Views)
