LabVIEW load error code 3: Could not load front panel
In my case, the code (front panel included) was working properly until I tried to change the connector pane. The next time I tried to open the file, it would not load. So I know it has a front panel - the problem everyone seems to be having is with the connector pane getting corrupted somehow.
If someone could help with my attached file, that'd be great. Thanks.
Message 131 of 176
(2,852 Views)
Good day!
I use Labview 2014 patch 1
After the usual save and exit the file .vi longer open, writes an error:
An error occurred loading VI 'KM_200.vi'.LabVIEW load error code 3: Could not load front panel.
Please help restore .vi file
Message 132 of 176
(2,825 Views)
@mnml_mouse wrote:
Good day!
You should probably start your own topic since this one was marked as solved.  You'll get more responses that way.
Bill
CLD
(Mid-Level minion.)
Message 133 of 176
(2,794 Views)
mnml_mouse started it's own thread here
Message 134 of 176
(2,751 Views)
I've had the problem described in this thread using Labview 2011. I tried modifying the .ini file but with no luck, please help!
My vi is attached
Message 135 of 176
(2,671 Views)
If you use the 2009 version of labview, your problem solution refrence is described in the blow link:
http://www.ni.com/download/labview-development-system-2009/1542/en/
Sincerely
Shahsavari
Message 136 of 176
(2,648 Views)
Hi.
How can I open and run 2011 Labview VI's in Labview 2014 upgraded version. I need a help regading this. shooting an error 10 code, I am not able to run and load it.
thanks in advance,
Chethan
Message 137 of 176
(2,581 Views)
do you use copy.vi? please post a screenshot from the error
Message 138 of 176
(2,576 Views)
Thanks for your reply.
I didn't save error screen shot. Will post it if I face in future.
I have to start from begining again, currently my system has 2011 version and upgrading it to 2014 Labview Full Development vesion.
Can you give me step by step to procedure to run/update 2011 VI files in 2014 version.  So that I should not loose original VI's.
Help me
Thank for your response,
Chethan
Message 139 of 176
(2,567 Views)
The more recent version of LabVIEW can open the VI, but there is no guarantee that the VI will run properly without editing. Please check the upgrade notes for the version of LabVIEW you are trying to upgrade to for more information.
Did you get the following error message  "LabVIEW load error code 10: Version of VI is too old to convert to current LabVIEW version" ?
Message 140 of 176
(2,551 Views)
