LabVIEW is Crash
@imkakakhel wrote:
I have attached a short clip while running the labview.exe file. i hope it helps you to understand my problem.
Don't have or want a 7z app on my phone.  Drop a video in the post editor.
"Should be" isn't "Is" -Jay
Message 11 of 14
(828 Views)
HI,
Can't post video directly that's why converted to zip file.
Message 12 of 14
(807 Views)
Accepted by topic author imkakakhel
Hello Everyone, Thank you who helped me regarding my issue. Appreciate your time.
The issue has been resolved. the problem was occurring due to several reasons.
1) LabVIEW 2017 Sp1(32-bit) wasn't suitable for window 10 (64-bit).
2) Had to un-install LabVIEW including below mentioned folders:
  • C:\Users\<Username>\Documents\LabVIEW Data
  • C:\Program Files\National Instruments
  • C:\Program Files (x86)\National Instruments
  • C:\Users\<Username>\AppData\Local\National Instruments.
3) had to make some changes in firewall setting
4) Couldn't find NI error reporting (NIER). still unable to send to report to ni.com.
Message 13 of 14
(786 Views)
#1 is not true.  For as long as there were 64-bit operating systems around, the recommendation was to use 32-bit LabVIEW on the 64-bit operating system.  Now this was due to the lack of toolkit support, which has been very much mitigated, but it is still considered a valid, if not preferred, combination.  So if this was the basis of your fix, I'd say it was probably fixed due to some other issue that was resolved by reinstalling.
Bill
CLD
(Mid-Level minion.)
Message 14 of 14
(771 Views)
