LabVIEW is Crash
Hello Everyone,
I'm encountering difficulties with LabVIEW. My current version is LabVIEW 2017, and it was functioning smoothly until I attempted to update LAVA pallets and make some other upgrades using VI Package Manager. Unfortunately, ever since that attempt, I have been unable to open LabVIEW, and every time I run the .exe file, it crashes and displays an error message. Even after attempting to reinstall the software, the issue persists. I would greatly appreciate any help or guidance from anyone who may have encountered a similar problem or knows how to resolve this issue. Your assistance would be invaluable to me.
Regards
Message 1 of 14
(2,967 Views)
Can you be a bit more specific.?
What exe are you running that causes that crash?
You claim you use LabVIEW 2017 but the crash report is during a LabVIEW 2014.0.1 DAbort.  (And that shows you are missing critical patches in 2014!)
"Should be" isn't "Is" -Jay
Message 2 of 14
(2,945 Views)
hi,
I am using LabVIEW 2017 Sp1, whenever I try to open my LabVIEW.exe it crashes, initially I was having the error attached in earlier post (found similar post online). some time error appears sometimes it just crash when software tries to initialize.
1 ) I tried to run as an administrator aswell didn't work
2) tried to install latest patch file didn't work
followed several steps mentioned in below link, couldn't manage to find the problem.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9TXSA0&l=de-AT
Message 3 of 14
(2,931 Views)
Captured the error coming on my pc
Message 4 of 14
(2,924 Views)
did you submit the report to NI? If you click "view report", is there anything interesting?
Message 5 of 14
(2,916 Views)
I tried multiple times but now the error is not coming, only crashes when i try to open it. i doubt it is not able to connect with the server.  I was unable to send the report too.
Message 6 of 14
(2,899 Views)
here are few error when I logged out and try to login again.
Note: it is very 1st page asking for license management.
Message 7 of 14
(2,895 Views)
hi,
with view report it directed to this folder (files attached):
error via sending the report :
I can not off my firewall as I'm using company's pc Its restricted with some changes. on the other hand i gave access to LabVIEW to communicate through windows firewall.
Message 8 of 14
(2,870 Views)
  • You need to allow access for NIER not LabVIEW to send NI Error Reports to NI
  • I am still unclear what app you are launching. That LabVIEW Licensing Wizard screen looks nothing like the LabVIEW Splash screen that launches when you run LabVIEW.exe to open the 2017 LabVIEW IDE.
Message 9 of 14
(2,850 Views)
I have attached a short clip while running the labview.exe file. i hope it helps you to understand my problem.
Message 10 of 14
(2,842 Views)
