LabVIEW in focus
Hi
I need to know if LabVIEW is in focus. Not just a single window but all windows contained in an .exe or the development environment.
Using the user32.dll:GetForegroundWindow is not an option as it returns any window handle id.
Any god ideas
Regards Kahr
Certified LabVIEW Architect
CIM A/S
(3,257 Views)
Hey there are those that would say I'm at my best when giving "god" answers, but be that as it may....
The user32.dll:GetForegroundWindow call returns a reference to whatever window is on top, but given that reference can't you find out the name of the process that owns it?  I found this code on stackoverflow that illustrates several calls.
Mike...
LabVIEW Champion
(3,205 Views)
Arghhh...
Forum can't keep up with my speedtyping - missed that final o.
Some might consider You a god Mike (-;
I'll track down someone who can translate that strange textual code into wires.
Any other god ideas. Perhaps some already made that wrapper.
Regards Kahr
CIM A/S
(3,188 Views)
Now that you mention it I seem to remember a fellow names George Zou (I think) that had a set of wrapper VIs for a bunch of window operations.
Mike...
LabVIEW Champion
(3,174 Views)
Hi Kahr.
I have made a small example, that also uses the user32.dll:GetForegroundWindow function. I simply record the original handle, and then compare that with the current handle.
If you have multiple windows, I believe you can extend this idea, and simple record the new window handle and then have two compares.
Can you use this example?
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
(3,125 Views)
