How to detect if RTEXE is running on PXIe-8133 RT Controller
i need to know from my PC if some RT executable is running on remote RT machine (PXIe-8133).
Is there any way how to detect in LabVIEW if some application is running on Real-time and possibly which one?
Thanks a lot.
Martin
(3,516 Views)
If the executable is created with LV, you could try to connect to it using VI Server.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,484 Views)
Hello Mike,
thanks for a reply. Yes, rtexe was built in LV2013.
How can I programmatically do it?
I tried to use Open Application Reference and then Open VI Reference, where i placed rtexe path instead of vi path, however I got error 1059: Unexpected file type.
Which function should I use to connect rtexe using VI Server?
Thank You very much.
Martin
(3,479 Views)
If you use the open VI reference, you have to specify the name of a VI that is currently loaded in the running instance you referenced - like "main.vi" or something like that.
Mike...
LabVIEW Champion
(3,476 Views)
Thank You very much for your help.
I think that i know what You mean but it isnt still working properly.
I got this path by calling Current VI's Path in built RTEXE on RT target.
I looks like "c:\RT EXE Folder\Main.rtexe\Main.vi".
However when I tried to connect to this using first Open Application Reference with machine IP and port number = 3363 and then Open VI Reference with just created application reference and the vi path above, I am still getting Error 7: File not found.
I think that there has to be something wrong with this vi path because when I tried the same approach on RT target (without Open Application Reference) I got the same error 7.
But the path I just copy from Network Shared Variable therefore any typo is impropable.
Do I miss something?
(3,462 Views)
Accepted by topic author mavlc
The big point is that calling a remote VI in this way, you are assuming that the VI is already in memory. In that case you don't have to give a complete path, just the name of the VI.
Mike...
LabVIEW Champion
(3,448 Views)
Yes, it works!!! Thank you very much.
(3,418 Views)
