Showing results forĀ
Search instead forĀ
Did you mean:Ā
LabVIEW at 20!
Guys n Gals,
The discussion seems to have gone a bit off topic. But its nice to sometimes discuss other things too like the one goin on here. Great going LabVIEWers. We're all enjoyin it.
Giridhar Rajan
Automation Engineer, Design
Cruiser Controls
Mumbai, India
Message 81 of 176
(5,371 Views)
Hi LabVIEW šŸ™‚
I started with LV5.1
I did not catch up when you were born, but I am catching you up since you were 5.1 šŸ˜‰
Congrates & Cheers!
ian
Singapore
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
ä¾ę©äøŽLabVIEW
LVVILIB.blogspot.com
Message 82 of 176
(5,150 Views)
can someone please tell me , how can i write any charging battery program in LabVIEW
Message 83 of 176
(5,109 Views)
Hi
The only thing you need to do is to monitor temperature,voltage and pressure and you get a goo feeling when a battery is charged.
You could go in with a high current and drop that when the battery is charged.
Be sure to monitor each battery and do not use sets of batteries.
good luck
(buying is less fun but probably cheaper)
greetings from the Netherlands
Message 84 of 176
(5,110 Views)
thanks for the reply!
i ahev values of the volatges and currents.and temperatures.
i take the values of the voltages and currents from chargecontoller and write a program in LV to charge a battery
i wonder there how can i give  the output of the LV to battery.
Message 85 of 176
(5,107 Views)
I would highly recommend that you start a new thread for a new problem. This has very little to do with "LabVIEW at 20!" šŸ™‚
(Actually, we already went over this, see our earlier discussion: http://forums.ni.com/ni/board/message?board.id=170&message.id=181514#M181514 )
Good luck!
Message 86 of 176
(5,076 Views)
Yeah. So we're supposed to discuss how we first interacted with LabView here right?
Well, it was a dark and rainy night at the monestary... <thundercrash, boom, thundercrash>... Labview and I were alone near the front pew and all the candles had blown out from the gusting winds.  I didn't want to do it, really I didn't, but it was dark, I had nowhere to go, and Labview told me I didn't have a choice.  Everything after that was kinda fuzzy...
Next thing I knew, I was waking up in the dumpster behind the monestary with .VIs spewing outta my A$$, and the strange ability to dynamically manipulate loops and variables, if thens and else's, without typing a single line.
I have vowed since then to seek my vengance, that was 7 years ago....
šŸ™‚
Message 87 of 176
(4,997 Views)
As demonstrated by IEC's contribution, the damage that LabVIEW can do to the human brain is increstonishing . May be I should stop right now and turn to LabWindows... šŸ™‚
Chilly Charly    (aka CC)
Message 88 of 176
(4,964 Views)
Started in 1989 at the Kennedy Space Center. I was teaching myself C and hating it since I am so slow on the keyboard. It was just the start of using PCs for conrol and the like. We were doing a lot of studying of packaged control software and they all were disapointing. I found a LV Ver 1.2 under someone's desk and the rest is history. The Shuttles started leaking hydrogen that summer and myself and 2 techs built an instrument that found the leaks in 10 days. I wrote the code in Laview. Even got a write up in Macworld. The NI guys were increadably supportive. Thanks Tony and Greg, you know who you are. Well, I've had a good carreer thanks to NI. I've been through the "that's a toy, not a real language" stuff for years and I still get a kick out of stuffing it in their faces.
Dave Wedekind
Message 89 of 176
(4,952 Views)
HI.. i'm using labview PDA pocket PC 2003 simulated version for my knowledge base.. I want to put a picture on my PDA screen but it appears as a enlarged one.. i tried the link -- KB 38EJRHFQ: How Do I Put a Picture or Image on My LabVIEW PDA for Palm Front Panel?   but it results out with nothing.. Is it because i'm using a simulated version?? will this be awrite if I use a real PDA hardware..
Please suggest me regarding this..
thanks and regards
vishwanath
Message 90 of 176
(4,916 Views)
