LabVIEW and "USB to 1-wire" (DS2490)
OOps..  Sorry..  I should have mentionned that I am using the LinkUSB interface which emulates a DS2480B USB inteface from Dallas Semiconductor.  I am not sure how different it is from the DS9490R.
Message 21 of 55
(4,714 Views)
With the DS2490 you need the DLL, ibfs32.dll.
- tbob
Inventor of the WORM Global
Message 22 of 55
(4,706 Views)
Oh yes... The DS2490 is a USB to 1-wire bridge chip..
Can you not setup the Mode Command (hex) with the appropriate number of bytes for the state registers and send it over serial?
I'm just curious..
Message 23 of 55
(4,697 Views)
I'm just curious..
You would have to know the commands.  I've never seen this info on Maxim's website.  Maybe it is there somewhere.  The white papers say to use the DLL.  It is free, convenient, and proven to work.  So why not use it.  I guess if you like a challange......Smiley Wink
- tbob
Message 24 of 55
(4,672 Views)
I happen to be working with the DS2431 and coding everything to talk to a USB-to-Serial interface using VISA. It makes life really simple. :)
Message 25 of 55
(4,665 Views)
Ray:  Sounds like you are having fun.  I'll stick to the DLL since all my code is already written.
- tbob
Message 26 of 55
(4,660 Views)
you know me... I always have fun..
Message 27 of 55
(4,629 Views)
You’re right.
If you are interested, in attachment, you will find my code that open an USB1WireReader (DS9490) device,write x bytes (by 8bytes= one scratchpad), then read the new values  and verify the data. The  first 1wire-DS2431 found on the 1wirebus is selected.
Now, I’m looking to implement a CRC control in place of write and read to be safer.
I'm still coding my application...
Marc
Message 28 of 55
(4,606 Views)
-deleted-
Message 29 of 55
(4,593 Views)
Hi Marc,
I am trying to run Main_WRV_cycle .vi from the zip file. But I think some SubVI's are missing like WriteScratch.vi, and many SubVI's from ReadScratch.vi. Can you please post it if you have them?
Message 30 of 55
(3,920 Views)
