‎03-24-2008 02:42 PM
‎03-24-2008 03:10 PM
‎03-24-2008 03:11 PM
‎03-24-2008 03:13 PM
‎03-24-2008 03:56 PM
PaulG. wrote:
I had no trouble at all with VSS but our IT guys didn't like it.
Perforce is pricey.
dan_u wrote:
But I disagree with tst that committing every single recompiled VI is useful as this might cause lots of conflicts when multiple developers are working on the same project. We're using conditional disable and different targets so VIs recompile basically always.
‎03-26-2008 01:09 PM
‎03-26-2008 02:23 PM
‎03-26-2008 02:24 PM
Paul, you still haven't said what Subversion-specific problems you ran against.
Whether you believe it or not is irrelevant - LabVIEW does keep the compiled code in the same file as the source code and does recompile at times where you might not expect it. TSVN simply has the design of working through the Windows shell and displaying all changed files very prominently. Personally, I can't really see myself working with TSVN and not committing regularly. If I wouldn't, my Explorer view would be full of red exclamation marks. I suppose I could set it up not to show those icon overlays, but I happen to like them.
‎03-26-2008 03:36 PM
‎03-26-2008 03:40 PM
