LabVIEW Time problems
I am simulating a sine wave signal and am recording when it is within a certain range. The data is being recorded into a table in labVIEW. I have set the Build table to include the time data, but it is recording the time as new years in 1904. How do I correct this?
Thank you for reading.
Message 1 of 8
(2,354 Views)
Hi Patrick,
@PatrickClancy wrote:
I am simulating a sine wave signal … but it is recording the time as new years in 1904.
My glassball says: You need to set a correct t0 in your waveform!
What about attaching your VI when you have problems with your VI?
Message 2 of 8
(2,347 Views)
@GerdW wrote:
Hi Patrick,
If you need money, just say so.  You didn't have to trade in your expensive crystal ball for a cheap glass one!
Bill
CLD
(Mid-Level minion.)
Message 3 of 8
(2,342 Views)
Hi GerdW,
Is it possible to remove the date part altogether and just leave the time. I am still learning how to use labVIEW so any help would be much appreciated.
Kind regards,
Patrick
Message 4 of 8
(2,314 Views)
Hi GerdW,
Kind regards,
Patrick
What is the reasoning behind separating the time from the date?  The same times happen daily so that information is essentially useless without date information.  Perhaps it is "relative time" - i.e., "the time since time0"?
Bill
CLD
(Mid-Level minion.)
Message 5 of 8
(2,310 Views)
Hi Billko,
I wish to have the table not to include the date as it makes it look very messy and harder to read. I can still work with the data if it remains, however I would like to learn how to remove it incase it causes problems for future projects.
Kind regards,
Patrick
Message 6 of 8
(2,304 Views)
Accepted by PatrickClancy
not to include the date ...
I would like to learn ..
If you don't want to include the date part, use formatting functions to display only the time portion.
Message 7 of 8
(2,295 Views)
Not only does that work all day but, since the date portion is there but not displayed, it works all night too!  It's awful when you come in in the morning and find 10 hours of data before the first reading you actually took.  (I sleep late)
"Should be" isn't "Is" -Jay
Message 8 of 8
(2,276 Views)
