‎11-17-2007 09:33 AM
‎11-17-2007 12:41 PM
‎11-18-2007 08:28 AM
‎11-19-2007 02:01 PM
In regards to your Post Script, do you mean running a LabVIEW application off of a network server?
If so, I do not believe this would be recommended; for instance, LabVIEW is not supported on Windows Server 2003. If this is something you would prefer to do, you might consider the Volume License Manager.
Let me know if I've misunderstood.
Cheers,
Emilie K | National Instruments
‎11-20-2007 06:34 AM
‎11-26-2007 02:03 PM
Hello Sharonoff,
I would say that any of our Real-Time targets would be ideal for this kind of application. This includes our PXI, cRIO and FieldPoint controllers. I believe that if you are doing serial communication, I believe you can get away with using a FieldPoint controller (most likely the cheapest solution). However, if you are doing some complex signal acquisition with any sort of signal conditioning, you may consider our cRIO or PXI controllers, as the I/O modules associated with these are much more robust.
I think you best bet is to talk to us directly. We have an several technical sales representatives that are more than happy to flesh out your solution with you and provide you with pricing information unique to your profile. Call (888) 280-7645 get direct help selecting a product or request a quote.
Cheers,
Emilie K | Applications Engineer | National Instruments
‎11-27-2007 03:23 AM
