integration acceleration array
Hi all,
Just a weird question. I know that by integration I can go from an aceleration in m/s^2 to m/s and finally to distance in m.
The only question is what sort of integration block i have to use with what properties? Anyone an idea about the usuage of integration within LabView 7.1?
Thanks in advance!
Patrick
(3,236 Views)
Hi Patrick,
In 7.1 there is a subvi called Integral x(t).vi which handles array integration. There is also a point-by-point integration subvi in the analyze function palette. However, you need the Full LabVIEW version for these vis. If you only have Base, you will need to create an algorithm on your own or maybe call a dll if you find one.
Pelle S
Account Manager
National Instruments Sweden
(3,213 Views)
