LabVIEW Programming Types
i am beginner in LabVIEW. I would like to know and learn how many types of LabVIEW programming types we have.
like 1) LabVIEW FPGA. 2) LabVIEW RT Programming.
i know only these two. are there any other types of LabVIEW programming?
Message 1 of 14
(6,361 Views)
Hi bhima,
its always the same "LabVIEW".
Do you want to know the number of suites, modules and toolkits?
Message 2 of 14
(6,353 Views)
Thanks for the reply.
no I want to know how many ways we can program any NI Hardware using LabVIEW like LabVIEW Real Time Programming, LabVIEW FPGA Programming.
I know only these two types.
are there any other type of LabVIEW Programming methods that can be used to program NI Hardware.
Message 3 of 14
(6,324 Views)
Accepted by bhimaabhilash
Depends on the hardware.  NI DAQ cards cannot be programmed with LabVIEW FPGA (unless they are R series cards).  NI FlexRIO needs LabVIEW FPGA.  In those cases they are not really 'options'.
ALE Consultants
Message 4 of 14
(6,301 Views)
A) LV FPGA
B) LV RT
C) LV DSC
D) LV Vision
E) LV Control Design and Simulation
F) LV State Chart
G) LV SoftMotion
H) LV MathScript for RT
Ben
Message 5 of 14
(6,292 Views)
Thank you Ben
Thank you  Terry_ALE
Message 6 of 14
(6,226 Views)
@Ben wrote:
A) LV FPGA
B) LV RT
C) LV DSC
D) LV Vision
F) LV State Chart
G) LV SoftMotion
Ben
You missed myrio and robotics environments, and maybe a few others,
The general rule though is "You can do that with LabVIEW "  some addons and toolkits do make it easier to use LabVIEW for different solution domains.
So, let's turn the conversation around.... What do you want to do with LabVIEW?
"Should be" isn't "Is" -Jay
Message 7 of 14
(6,195 Views)
Just I want to know and learn how NI Hardware can be programmed. As of now I know they can be programmed with FPGA and with out FPGA.
Message 8 of 14
(6,176 Views)
You have normal LV ofcourse, as in normal desktop programs apart from the others already mentioned.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 14
(6,108 Views)
