Showing results forĀ
Search instead forĀ
Did you mean:Ā
LabVIEW Path Dirctory
HI LV  Experts,
My Project.
I am working in a Project where LabVIEW Modules are Called in NI TestStand in Run Time Environment.
All Complied information are stored in "C\Users\Document\LabVIEWData" by Default. when different users are Logged in the same Machine i need to compile LabVIEW Code Modules in all the User Accounts/Logins.
To Overcome this issue i have changed the "Default Data Directory" and Mapped the LabVIEW Data File.
But still i need to repeat the same in all logins (Mapping Default Data Directory)
Is there any way i can configure in single user Login and use the same in all the available Login in a machine
Palanivel Thiruvenkadam | ą®Ŗą®“ą®©ą®æą®µąÆ‡ą®²ąÆ ą®¤ą®æą®°ąÆą®µąÆ†ą®™ąÆą®•ą®Ÿą®®ąÆ
LabVIEWā„¢ Champion |Certified LabVIEWā„¢ Architect |Certified TestStand Developer
(2,920 Views)
Compile your code modules into Packed Project Libraries (PPLs).  Then your TestStand sequences can call any public VIs inside of those PPLs using the Runtime Engine.
(2,872 Views)
To allow "all users" to access my Builds (and other "compiled" data), I save compiled information in "C:\Users\Public Documents\<xxx>" (and specifying this path in the Build Specs), with Shortcuts to the Exe's save in C:\Users\Public Desktop (which is, in Windows 10, a Hidden Folder).  You can make the folders "Read and Execute" for non-admin Users if this is a concern ...
(2,860 Views)
I guess you can make a symbolic link (mklink) in the teststand executable's search folder, pointing to the LabVIEW lib. That should work for all users.
A ppl is probably a more decent way to fix the problem.
(2,580 Views)
