LabVIEW NXG 3.1 and Teststand UI controls not working
Hi!
After I upgraded to LabVIEW NXG 3.1.1 do I have problems with Teststand UI controls.
I can see the Teststand UI controls palette:
Teststand PaletteTeststand Palette
But when I choose one of the controls, I get the following: "No convertible Data"
The Teststand UI controls, are installed together with Teststand 3.1.1, but it might be an older version?
Anders Pedersen Sekanina
sekanina.dk
(3,164 Views)
Hi AndersSekanina,
It sounds like you upgraded from a previous version of NXG to NXG 3.1.1, and the NXG upgrade did not play well with the TestStand NXG Addon. I will try to install NXG 3.1.1 with your version of TestStand and see if I can reproduce your issue.  A couple questions:
  • Was TestStand installed before the upgrade, and was working previously?
  • What version of TestStand are you using (3.1 is from 2007)?
  • Have you tried re-installing the TestStand NXG Addon?
Frank
(3,085 Views)
Hi Frank!
Thank you for the reply.
- I had it working on an other machine, but the disk crashed. I think it was NXG 2.x and Teststand 2017.
- Sorry I am using NXG 3.1.1 and Teststand 2019
- No, I will try that one of the coming days.
sekanina.dk
(3,059 Views)
Great, thanks for the info. NXG 3.1 does support TestStand 2019 per below. I will test out that combination.
TestStand Compatibility with LabVIEW and LabWindows™/CVI™
https://www.ni.com/en/support/documentation/compatibility/18/teststand-compatibility-with-labview-an...
Frank
(3,042 Views)
Accepted by topic author AndersSekanina
Hi Frank!
I found the issue, I had only Teststand 2019 32-bit installed. I installed 64-bit Teststand, and now it works.
Thanks for the help!
sekanina.dk
(3,024 Views)
Great, glad to hear that it was an easy fix. Not a problem, happy to help AndersSekanina!
Frank
(3,009 Views)
