11-28-2017 03:32 PM
I would like to make a display which shows the action of a trim tab, elevator, and horizontal stabilizer of an airplane. I believe I can get the math to work so far as forces generated relative to airspeed and leverage due to placement of the trim tab, but I want to be able to graphically demonstrate the angles. Theoretically, I would like to be able to effectively animate an empennage fed values on a slider which indicate airspeed and trim tab position. Is there any way to do this?
11-28-2017 03:56 PM - edited 11-28-2017 03:57 PM
11-28-2017 04:15 PM
Holy cow, uh, I was thinking more of something that looks like this, where the angle values would articulate the joints at the yellow dots respective to the long axis of the appendage it is indexed from. Way simpler, only 2D. It would be easy enough to create indicators that show the total force at each point, but basically I want to animate this with a while loop so that as sliders are moved they will articulate accordingly.
11-29-2017 12:52 AM
Hi MakeIt,
- What about using the 2D picture indicator to draw your parts and joints? There are lots of drawing functions for 2D pictures…
- What about using a XY graph to "draw" images using plots? (It might be somewhat more complicated to fill the contours…)
