LabVIEW Error code 1556
Hi
I think I have managed to crack it, there were two vis that needed to be called up first.
Thank you to all who input
Best Wishes
Andrew
Message 11 of 12
(1,451 Views)
Here's an example taking a class constant and creating the DVR:
You could use it like this:
The "Set Value" VI is just a dummy, but it looks like this (approx like yours):
Here I didn't close the DVR - you should also in a real application use "Delete Data Value Reference", probably in some sort of "Close.vi" for your class.
GCentralI'm attending the GLA Summit!
Message 12 of 12
(1,451 Views)
