LabVIEW Application Error: The instruction at address x referenced memory at address y. The memory could not be written.
When trying to open LabVIEW, I get the following message, "LabVIEW Application Error: The instruction at address x referenced memory at address y. The memory could not be written."  I've disabled the startup services, clean boot or diagnostics startup, but I still get the message.  Any ideas as to why and how I fix it?  It seems to work fine on other machines.
(2,787 Views)
The standrd next step is to
Start Control panels >>> add remove programs >>> NI ....
Select the repair option then stand by to feed the disks.
Ben
(2,783 Views)
I've repaired.  I've uninstalled.  I've removed every instance of "LabVIEW" from the registry.  I've reinstalled.  All many times.  The memory addresses change from instance to instance, but the error continues to happen every time.
(2,780 Views)
If you are sure you are virus free then check the system Event Viewer and review the logs for a clue.
Take care,
Ben
(2,777 Views)
