LabVIEW 7 App Builder
Just upgraded from LV 6.1.
First time out with App Builder, I go to load the .bld file and get this a couple of times every time:
Error 6 occurred at Invoke Node in Dist read linkages.vi->Dist Cmp Settings to Disk Hier.vi->Dist Build App Image.vi->Build Application.vi
After that, there are no VIs listed in the VI Settings tab.
(3,014 Views)
Look at the following links for a solution
Error 7 at Invoke Node When Building a LabVIEW Executable
Getting Error 7 While Creating a LabVIEW 5.1 Executable
Error 1 at Invoke Node when Building Application
How Do I Mass Compile VIs, LLBs, or Folders in LabVIEW?
Zvezdana S.
(3,014 Views)
