Select With Options and choose Development Distribution to create an llb with all subVIs except vi.lib files. You can then use the Edit VI Library option under the Tools menu and make your main VI Top Level. If you plan on making this distribution the master, you should be aware that source code control programs don't really handle llb files.
The llb was originally created as a means to get around the old limitation of DOS file name lengths.
