LabVIEW 2026Q1 Web Server Issue
I installed LabVIEW 2026Q1 Late last week when it showed up in NI Package Manager, and when I went to access the NI Web Server (configured through the utility, and accessed through localhost:80, rather than the typical login screen it's just a blank page:
If you look at the source or do an "inspect" where you would normally expect the login to be, it's still there, but it seems like something broken about it.  I tested this with a couple of browsers (chrome & firefox) as well as in incognito mode / not... same thing everywhere
(539 Views)
I think port 80 is routinely blocked by firewall? Did it work before?
Bill
CLD
(Mid-Level minion.)
(515 Views)
This is just at localhost which is not usually blocked.
The "page" shows up (you can see the header)... just the login content is missing.
I think there's also typically a menu in the upper left as well (though that might be blocked by the login)
Definitely not a firewall issue.
(505 Views)
Some additional info:
I went back and tested on a VM with 2025 Q3 on it... and the same error seems to be there.
The only "older" system I had handy was one with LV 2023 on it -- which is the build system I use, and the last place I properly tested the Web Server.  This one still behaves the way I'd expect:
(426 Views)
