LabVIEW 2015 "not responding" on project open
I have been working on two projects in LabVIEW 2015 for a while.
Today I wanted to install an upgrade to LabVIEW 2015 SP1. This included a patch for 2015 SP1 f1.
After install and restart, I opened one of my projects again. LabVIEW froze with "not responding" in the title.
After several minutes I noticed that the Project Explorer had in fact appeared, but when I do something (try to open a .vi) it freezes, and hangs again.
I tried opening the other project, and it works fine.
I have the exact same files on a laptop, that I had not upgraded to SP1 f1, and everything works fine there.
I troubleshooted for a little while, but decided to uninstall SP1, and install 2015 again.
After doing this, I still have the same problem with project number 1.
I will attach the .lvproj here, in case someone is a wizard, and can tell something from it.
LabVIEW hangs on the message "Opening Hawk.lvproj".
Any advice or help is welcome! Thanks!
Oksavik
(3,976 Views)
Accepted by Oksavik
As I mentioned the Project Explorer did finally appear after about 10 minutes of "not responding".
I clicked "Save all", and left it. When returning, it was responsive again, and since then: no problems.
I don't know what caused it, but "save all" seems to have solved whatever problem LV had with my project file.
Perhaps this will help someone else in the future.
(3,969 Views)
Is it possible that upgrading somehow triggered something to mass compile?
Bill
CLD
(Mid-Level minion.)
(3,937 Views)
