05-01-2012 09:01 PM
I un-installed both LabVIEW 2011 and 8.5. Then, I re-installed 8.5. The same "nip2p.dll is missing" error occured. I deleted all dll starting with the prefix "ni" in the folder system32, but that didn't fix the problem. Any thoughts on that?
05-02-2012 11:42 AM
We generally do not recommend manually deleting dll files, but the solution mentioned earlier outlined a reinstall of LabVIEW 8.5.1 and (older) DAQmx after doing so. Did you try this step as well?
05-02-2012 02:05 PM
Yes, I did. I removed all NI software from my laptop, and I re-installed LabVIEW 8.5 and (older) DAQmx. I actually installed 8.5 and not 8.5.1.
05-02-2012 07:15 PM
The "msiblast" thingy mentioned above should fix up registration.
It looks like the dll is still registered. Try that to cover the steps outlined above.
Ben
