LabVEIW FULL version and polymorphic VIs
Hi, I can seem to create polymorphic VIs with the Full version of LabVIEW (8.5), I thought that the professional version was required. Has this changed?
-Martin
Certified LabVIEW Architect
(3,581 Views)
Not according to the LabVIEW Help. Maybe you got the Professional by accident/luck?
(3,563 Views)
I only have pro, so I cannot check myself. Is it possible that you are still in eval mode?
(3,557 Views)
I have confirmed that I have the "Full development system" in the About window. The Getting started window reads "Licensed for full version". And I'm not in any sort of evaluation mode. I can't build applications (no app builder). Maybe there are some limitations on polymorphic VIs when developing under the full version, I have not used the VIs I created properly yet - but they seem to run without error.
-Martin
(3,539 Views)
I agree that the LabVIEW help for 8.5 does state that "You can build polymorphic VIs only in the LabVIEW Professional Development System".
With the release of LV 8.6 this line has been removed from the 'Building Polymorphic VIs' help page which implies this functionality is now available in the FDS. I don't know how this can effect your 8.5 activation but I can look into it in more detail if you like??!
Rich
NI | UK
(3,508 Views)
Can you confirm the full polymorphic VI functionality is available in the full development system from version 8.6 and onwards?
Message Edited by Martin.D on 10-01-2008 09:46 AM
Message Edited by Martin.D on 10-01-2008 09:47 AM
(3,504 Views)
I will get back to you later on today if that is ok as I will need to set up a clean machine and test this out.
Regards
Rich
NI | UK
(3,500 Views)
