10-01-2008 03:21 AM
I am writing a C# application and have LabVIEW 8.2 and the Application Builder. I want the application to call different standard VIs included in LabVIEW. One way to solve this is to create a blank VI, insert the desired standard VI, have the Application Builder create a DLL and then let the application call the DLL. Something tells me there must be a shortcut to this, is there? Aren't all standard LabVIEW VIs really DLLs underneath the surface? Can I somehow call those DLLs directly?
10-01-2008 03:33 AM
arnold_w wrote:Aren't all standard LabVIEW VIs really DLLs underneath the surface?
NO, LabVIEW is a programming language and contains a lot of primitives. Some VIs are wrappers for DLL's but even calling these from C(#) might be a problem.
You can exploit the LabVIEW ActiveX interface to perform all the actions you want.
Ton
10-01-2008 03:53 AM
