LV performance with Dual core processors
I have tested the vi describe in the note "LabVIEW and hyperthreading"
[broken link removed]
on a Pentium D 940 dual core 3,2GHz PC.
The results are strange.
With one for loop (testperf2.vi) the execution time for 400000 iterations is 3,4 s
With two parallel loop (testperf3.vi) the execution time for 400000 iterations is 7 s
Is I set the Affinity to CPU 1 only the execution times are both about 3,5 s !
I don't understand, can somebody explain these results ?
(3,272 Views)
It seems to me that perf3 is processing twice the data so you are seeing time to execute * 2 threads + overhead.  If I am wrong I do apologize in advance.
I ran perf2 on my 3,2 GHz PC using the progam defaults and I get 390 mSec that is about 10x faster than you are reporting.
A final note it that i am personally looking into purchasing a Core Duo laptop PC in the very near future.  Is there any performance data for the difference Core Duo Processors?  The T2300, T2400, T2500, and T2600s.  Am I wasting money with this technology?
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,247 Views)
Hi Matt,
Thanks for your test.
In perf3 each thread proccess half data.
The given process time is given for 400000 (the default value is 100000).
If I set the "Affinity" (In Windows task manager) to CPU1 or CPU2 (not both) (like a single core processor), the process time is better than with both CPU !
Thanks again
(3,237 Views)
Sounds like we need someone with access to a buch of PCs to do some benchmarking of performance.  Any volunteers out there?  Agree, your numbers do not make sense.
Matt
Message Edited by mfitzsimons on 06-01-2006 12:00 PM
Matthew Fitzsimons
(3,233 Views)
I'm also interested in this.
My super-duper Hyperthreading single core, filled to the teeth with warp engine 3GHz PC.... is slower than my regular 256MB, 2.4GHz PC...
And I recently, I upgraded my wife's PC with an AMD (finally switched camps) 1.8GHz and it kicks the butt off both my PC's!!!!
I am looking at newer / faster technologies, including the dual core, but I don't believe in the forecasted increase in performance.  Windoze doesn't support dual core.  Most applications do not either..  However, I would be interested in learning if there are improvements when using LV...
---- curious  ----
(PS:  then there are games... but who has time for that???)
(3,226 Views)
