setstate.cpp error
I have a cFP-2120 that network publishes data via shared variables to a monitoring vi that runs on a PC. Everything works fine for a couple days until LabVIEW crashes and says there was an error with the file "setstate.cpp". I saw an earlier post that mentions that this is probably a lack of RAM problem but looking at the memory profile, everything seems fine and in a steady state (as it should be because I'm not building up huge arrays or anything like that). Has anyone seen anything like this? The error log is given below.
This consistently happens after a couple days of run time so it does seem like some sort of memory leak.
Thanks very much,
Derek Mackay
#Date: Mon, May 22, 2006 11:22:41 AM
#OSName: Windows NT
#OSVers: 5.1
#AppName: LabVIEW
#Version: 8.0
#AppKind: FDS
.\editor\setstate.cpp(4299) : DWarn: can't realloc cleanup tbl
$Id: //labview/branches/Constellation/dev/source/editor/setstate.cpp#334 $
0x00670FA9 - LabVIEW <unknown> + 0
0x006712CC - LabVIEW <unknown> + 0
0x006748B9 - LabVIEW <unknown> + 0
0x006768DC - LabVIEW <unknown> + 0
0x00D5169D - LabVIEW <unknown> + 0
0x00D54114 - LabVIEW <unknown> + 0
0x00D56B02 - LabVIEW <unknown> + 0
0x00D650F3 - LabVIEW <unknown> + 0
0x00D597FB - LabVIEW <unknown> + 0
0x05C8C800 - <unknown> <unknown> + 0
0x00000000 - LabVIEW <unknown> + 0
0x00BDF040 - LabVIEW <unknown> + 0
0x000080EC - <unknown> <unknown> + 0
Message 1 of 1
(2,419 Views)
