LV 8.6f1- different decimal point at development & exe
In my program I want to use the decimal point  "." and not the local symbol of the PC.
So I turned of this option in the category "frontpanel".
In the development system this works fine, on the screen and in the saved data files (*.lvm & *.xls) the "."  will be used.
But when I build an exe file of my program there will always be used a ","  as decimal point (on the screen of the same PC and in all saved data files).
Can anybody help me ?
jan
LV 8.6f1
(3,761 Views)
Accepted by jan9101
The option is stored in the LabVIEW.ini file. This is what is used by the development environment. When you build an exe, the exe uses application_name.ini. So copy the ini setting (useLocalDecimalPt=False) to application_name.ini and include that in the distribution of your app.
(3,757 Views)
Hello Dennis,
thanks a lot, this works fine.
Is that behavior normal or bug ?
jan
(3,749 Views)
The behavior is by design.
(3,737 Views)
thanks for info, just a small correction, the line should be
useLocaleDecimalPt=False
(Locale not Local)
Marek.
(3,301 Views)
