LABVIEW 7.1 20020
hello  I am acquiring at a rate of 8000hz, 16bits. My LowFc = 0.01 and my high FC is 1500hz. still I am getting that error 20020. I tried playing around with the filter parameters however that isn't working.
why is the filter giving this error ?
labview 7.1
thanks very much
帖子被xiuming在 05-25-2009 09:47 AM
时编辑过了
Message 1 of 30
(5,395 Views)
You need to specify the sampling rate when converting the I16 (sound) data to dynamic data. Use "Build Waveform", wire your data to Y and specify dt (=125us at a sampling rate of 8kHz).
Take care, when I open your VI in LV 8.5 it looks like you're acquiring data at 11.025 kHz and not at 8 kHz.
Hope this helps,
Daniel
Message 2 of 30
(5,380 Views)
Using Express VIs is bad programming style and should be avoided. Just use a plain filter. Se picture
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 3 of 30
(5,366 Views)
how can i specify the sampling rate to the conversion?
thanks for your help
Message 4 of 30
(5,354 Views)
The rate that you have set to 11025 in the cluster wired to the SI/SO config is the sample rate.
Ps in the filter block set the init/cont boolean to true with a constant
Message 5 of 30
(5,346 Views)
you use which filter block? i am sorry  i can't find it.
Message 6 of 30
(5,348 Views)
Accepted by topic author xiuming
Se picture. Now the rest is up to you
Message 7 of 30
(5,345 Views)
yeh!
thank you very much.
Message 8 of 30
(5,330 Views)
there is not error,  but i can't hear anything. i don't know why, before adding this filter it is all right.
and can you tell me what's the diffrence between 'menu deroulant' and 'menu text'?
thanks.
Message 9 of 30
(5,294 Views)
Sorry I have not used the Labview sound system for while. I forgot the rate value is enum not a integer. You have to convert it to a numbersee picture. You will find the small "case structure" in the SO config or the SI config VI just copy it and paste it in
Message 10 of 30
(5,286 Views)
