list
Hi all : Attach see file please … I build an application I choose text from list ,, all worl well .. but what I need to do that if I choose text from list then I immediately exit from loop .. not when I press set … how can I do that  thanks
(2,938 Views)
Accepted by topic author elyan
You could add another event to that case for Select Device from List:Value Change.  Now if the list changes or you hit Set, the event will fire.  Whether you truly want this operation is another question.  I think it would essentially mean you never hit the set button.  And suppose the user changes the device to something they didn't want accidentally.  There is no way to correct that.
You also have a few extra indicators out in left field on the front panel that seem to duplicate each other.
(2,933 Views)
