L*a*b* color : Problem with the Luminance value
Thanx mathan.
Message 11 of 14
(938 Views)
This is expected behavior. Presumably the value is internally calculated on a 0-100 basis. However, on page 15-34 of the Vision Concepts Manual (July 2007) regarding CIE L*a*b* color conversion, it gives the following:
"NI Vision normalizes the result of the L* transformation to range from 0 to 255."
I am assuming this normalization is a linear scaling factor of 255/100, transforming the values from a [0-100] range to a [0-255] range. My guess is that this is done to give greater dynamic range when representing the L* value with just one byte.
Message 12 of 14
(920 Views)
Thanks for the search, Maxime.
As a matter of fact, the L* value returned by the vi is not coded as a U8, but as a Dble. Therefore the 0-255 range does not increase the dynamic range. And most color measuring devices return L* values in the 0-100 range. Clearly something as do be done. Should we advise the "Compagnie Internationale de l'Eclairage"(CIE) that their definition should be changed, or can we expect NI vision to follow more closely international standards in a near future ? 😉
Chilly Charly    (aka CC)
Message 13 of 14
(888 Views)
CC,
Post your CAR# here*.
Ben
*Note: The above link points to a thread in the LabVIEW Champions Discusion Forum and is availabe to LV Champions only. If YOU want to apply to be a LabVIEW Champion, see this link and click the "Join now" link. New Champions will be added every year!Smiley Wink
Message 14 of 14
(867 Views)
