L*a*b* color : Problem with the Luminance value
This is an issue with IMAQ vision :
In the Lab color system, the L component should range from 0 to 100, while the IMAQ RGBToColor vi yields values in the range 0-255.
Not a big issue, but still annoying...
Message Edité par chilly charly le 07-17-2008 04:33 PM
Chilly Charly    (aka CC)
Message 1 of 14
(4,903 Views)
Hi CC,
Lets pretend that I have never heard or seen that VI (because I haven't)
Where did you find that?
and
What is realy supposed to do for us?
Ben
Message 2 of 14
(4,893 Views)
Ben,
        It converts RGB to a different color format.But seriuosly dont have any idea on what CIE L*a*b means.
Message Edited by muks on 07-17-2008 09:57 AM
Message 3 of 14
(4,888 Views)
Thank you muks!
I haven't looke at the vision palette in a long time.
Ben
Message 4 of 14
(4,871 Views)
Ben i have a basic doubt.How do you bring the image inside the text area?
Message 5 of 14
(4,859 Views)
After you have posted with an attachment, clcik on the link to view it.
Copy that URL and go back and edit your post.
While editing, clcik that button that looks like mountains "Insert image" and then paste the URL into that dialog.
Close and submit your editied post.
Ben
Message 6 of 14
(4,855 Views)
Thanx ben
Message 7 of 14
(4,849 Views)
Ben a écrit:
Hi CC,
and
Ben
Hi Ben,
If you are not involved into color image analysis, this vi is useless for you.
Apart RBG, there a number of standard ways to represent color. See http://en.wikipedia.org/wiki/Color_space
CIE L*a*b* is fairly popular where I work. So it would be nice if the tools proposed in IMAQ vision where bugfree...
Message 8 of 14
(4,823 Views)
You can also use Code Capture Tool to insert ur front panel or block diagram or both into ur post.... Its easy. Try it out.......
Message 9 of 14
(4,799 Views)
I created a Corrective Action Request about your issue. Request ID# 120500.
Message 10 of 14
(4,785 Views)
