Keyence SR-752
Hello:
I am using a Keyence SR-752 camera. I am written a VI to control and get data from the camera thru the network. I have been able to connect to the camera, turn the lights ON/OFF get settings but when I select the LiveView to view the Data Matrix barcode labview goes into severe shotdown it needs to turn off to be able to run labview again.
I am using labview 2010 SP1
Keyence SR-752. It comes with some samples VB.net and VC#.net I am using labview .net constructor with property node to connect. The only issue I have is the forceble exit of labview. When I run in the project I have to reboot the PC in order to get labview to work otherwise labview is frozen it does not accept any
control inputs not even pressing stop run vi.
attach is what happens.
(4,479 Views)
Hi Toro,
I am unfamiliar with LiveView, is it a HW attribute or SW attribute? If it is a HW attribute is it definitely supported on your camera? If it's software do you have the same error with any other camera?
Scott B.
AE NI
(4,431 Views)
Hi Skirp:
I solve the problem. it was couse by MAX somehow MAX database got corrupted. I follow the info in the NI website on how to fix that problem.
Thanks for your responde.
(4,385 Views)
Toro,
I am glad that you solved your issue! Also thank you for posting the solution in case anyone sees this issue in the future!
Scott B.
AE NI
(4,363 Views)
