Keeping plot colors with the right data
 I apologize, but your example on this post is clearer.  I'll try this method.
Message 11 of 20
(1,908 Views)
I understand how this works now, but can't find a 'color box' to insert into the block diagram.  Pity the novice.
Message 12 of 20
(1,902 Views)
I don't suppose you've considered upgrading to a newer version of LabVIEW?
You can search the palettes to find a function by name.  I believe the color box constant is under Programming -> Graphics and Sound -> Picture Functions.
Message 13 of 20
(1,900 Views)
Also:
Not sure if this works in 7.1
1. select color box on the front panel but drop it on the block diagram
or
2. quick drop (ctrl + space) in block diagram and type  Color Box Constant
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 14 of 20
(1,898 Views)
No luck.  I found a box I could drop in the block diagram, but there is no control wire out.
Message 15 of 20
(1,890 Views)
Basically its a number (three bytes which represent a colour in RGB), just wire a numeric constant.
For example green is
0x65FF59
Message 16 of 20
(1,885 Views)
What does that sentence mean? Can you attach a picture?
Message 17 of 20
(1,883 Views)
Excellent!  That I can do!  As far as upgrading, I was sent 8.0 while still under warranty and the vi that I bought the whole package to do would no longer work.  Hence, I backed off 8.0, went back to 7.1 and here I am.  There are usually ways to do everything I need to do.  Thank you for the explanation!
Message 18 of 20
(1,880 Views)
I found the RGB to color vi.  Should work fine.  Thanks to all.
Message 19 of 20
(1,877 Views)
Success!  Thanks to all.
Ron
Message 20 of 20
(1,867 Views)
