Keep Vi Frontmost
Hi all!
I Have a problem. I have a Vi - call it Top - Level VI, and have another vi - call it Lower Level. In the lower level and the Top level are running continuously, using VI server. I registered events both side of top and lower level vis. I would like to use the lower level vi as a palett... Contains the functions only, and when I select a function from lower level, the event are handled in the top level.
I have already implemented everything, but How set the lower level vi to frontmost?
 (Keep the same functionality.)
At this point, when I click on the  Top level VI , another vi goes the background....
Could you help me that how to keep the lower level vi topmost? (without setting it's property dialog as well... )
+++ In God we believe, in Trance we Trust +++
[Hungary]
(3,438 Views)
Accepted by D60
Under the vi properties, you can set it to 'floating' (dialog is 'modal').
Felix
(3,435 Views)
:D:D:D
Sorry... Sucessfully Solved! 🙂
I've never thought that it could be so easy...(set window to Floating)
[Hungary]
(3,434 Views)
When I posted this question, I have already found out... 🙂
btw... thank your fast reply.... and accepted as solution...
[Hungary]
(3,426 Views)
