03-20-2009 09:34 PM
hello
I have a keithley 238 meter that measures current as the voltage is swept. It is GPIB device and hooked up to my PC through NI GPIB-USB-HS
adaptor. I want to control it using Labview 8.6. I used the VI available at your instrument driver network, which directed me to keithley website and is attached below.Keithley says the VI is an unsupported freeware. The VI is located at
http://www.keithley.com/products/currentvoltage/?path=238/Downloads#1
The first "example program" in this website is the VI that i am using.
Now the VI is working nicely. The VI sweeps the voltage and displays measured current as a table and a graph.
I just want to modify the sweep delay, but i cannot increase it beyond 1000ms. Why is it so?
The sweep delay is the time it pauses after each increment of voltage.
I dont know whether a modification in the VI is needed or settings of the NI GPIB-USB-HS adaptor are a problem. I checked the settings of this device under MAX- the time related settings are as follows
1) I/O timeout-> by default set to 13(10sec)
2)Antipolling- checked
3)then there are some termination settings and advanced settings, there is a setting, bus timing set at - 2(500nsec)
So are the GPIB settings wrong or code must be changed? How and where to change the code?
03-20-2009 10:53 PM
03-20-2009 11:36 PM
thanks!
the problem is solved.
