03-18-2009 02:11 PM
Bonjour,
J'ai une carte NI 4351 qui semble bien fonctionner. Avec Measurement & Automation Explorer je visualise bien mes températures pas de soucis. Mais dans Labview ou DAQ, il ne trouve aucun périphérique présent. Qu'ai-je raté ?
03-18-2009 02:14 PM
Sorry, I get missed with all the forum. I though I post in a french forum. Here's my question :
I've got a NI 4351 card, which seems to work correctly : in Measurement and Automation Explorer, I get temperatures without problem.
But in Labview or DAQ, it can not find any devices. Where am I wrong ?
Many thanks in advance.
03-19-2009 08:29 AM
Fisrt you need to know that the 4351, uses NI Daq traditional.
Then you need install the Daq trad support for Labview (in order word you need to install Daq Traditional after Labview).
After that you can go to the NI Example Folder, then seach and you must write 415x you will see many examples, you will have to write the good instrument descriptor.
Nacer M. | Certified LabVIEW Architecte
03-21-2009 05:23 AM
OK. I was able to use an example.
Thank's a lot.
