Join two files
I am generating two LVM files, but I need to join them to make them one, how can I do it?
(1,048 Views)
It depends, how exactly you would like to join both. An easiest way probably is to read both, merge, then save, something like that:
Graphs:
(1,040 Views)
the idea is to do it as if it were a single file with a continuous acquisition. because I am dividing the acquisition.
(1,034 Views)
Then you can use Append instead of Merge:
(1,010 Views)
system exec Copy File1 File2 > File3
Qestit Systems
Certified-LabVIEW-Developer
(946 Views)
This will not work (I guess), because you will get header in the middle of the data, please try yourself:
Please post your functional LabVIEW code (in additional, execution of the command
will result copy of the File1 into File2 and the string " 1 file(s) copied." inside of File3 instead of joined content), I think.
(938 Views)
My bad, it should be copy test.txt+test2.txt test3.txt
Yes, it's a pure append which might result in headers in the middle
Qestit Systems
(924 Views)
