Pixel Values via NI MAX always below 32000
I am using NI MAX to acquire Images from a Sensor. When using the same setup on a different computer I get the expected results, with pixel values up to  2^16.
Now I am using a different computer. Here the Pixel values never go beyond 2^14 and I don't understand why. Jumbo frames are activated, the firewall has an exception for the program and the ehternet cable is CAT6a, which should be good enough as far as I can tell.
The screenshot shows the histogram of the Image. There is a read out line in the image, thats why there are pixel with 2^16.
I would greatly appreciate it if anyone could help me with this problem!
Cheers
(520 Views)
Transport layer, cable's category, jumbo frames as well as firewall will not cut off bits from your data. It looks like you have slightly different camera's settings.
I see small peak at the end of the histogram, so the data seems to be utilizing full range:
Could be issue with signed/unsigned 16 bit representation, but it doesn't looks like this. Check your settings again.
(502 Views)
