JSON unflattening
Hi guys,
I'm having such a hard time with this little task, decoding a JSON string. I have a data mismatch. Can someone please have a look and give some advise? VI is attached.
Message 1 of 15
(11,226 Views)
Accepted by id911
Here
Message 2 of 15
(11,193 Views)
You can use this to create a control from a JSON string.
Message 3 of 15
(11,143 Views)
Wow, that's very useful! Thanks alot.
Message 4 of 15
(11,127 Views)
Hi Paul, did you test the llb with LV 2017?
Message 5 of 15
(11,024 Views)
I am also using json file to Deploy a classification model, earlier i trained a SVM classifier with csv file data set by which i get trained model file in JSON  format. now  when i give this json file as input to the classification Deployment, I always show the data mismatch between json & labview(Error Code - 370004, 370005). All the details & data are also attached.370004..png370004.,,,.png
Message 6 of 15
(10,888 Views)
Aman_Dhull,
I'd recommend starting a new thread for this question, as a new post is more likely to get traffic than this post from April.
Francine P.
Applications Engineering
Message 7 of 15
(10,872 Views)
Hey Aman and everyone else interested in Aman's question,
I found this is a double posting, therefore have a look at Re: Crash: access violation json as in that thread there are already some follow-ups to Aman's posting.
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
Message 8 of 15
(10,843 Views)
Hi id911,
I'm having the same problems with unflattening proccess.
When I flatten a JSon text with a similar structure, the unflattening proccess send me an error.
Can you help me?
Message 9 of 15
(10,663 Views)
Hey Dirizabal,
I recommend starting a new thread for your question, as a new post is more likely to be seen that a post hidden at the end of a marked-as-solved thread.
Regarding your failing un-flattening: You have two mismatched types:
CLADMSD
Message 10 of 15
(10,510 Views)
