Blinking of a NXG Button changes when Mouse over
Hi
I'm using a NXG boolean button (switch when pressed) to start a test and show an error by using the blinking property node. That works so far, but when i hover the mouse over the flashing button, the boolean text disappears and the blinking color changes. If i use a silver button colors remaining like they should. Has anyone faced that too?
(1,374 Views)
Hi there,
this sounds like a bug. what version of LabVIEW are you using?
maybe it's a known issue or fixed in new versions.
(1,151 Views)
