Issue converting Map to Array on sbRIO Target
I have been wanting make use of the new Maps datatype but I may have run into an apparent bug when running on a sbRIO 9637.
I have a very basic Map with a String Key and a Double Value. When I try to convert my Map to an Array using a For Loop, the result is an incorrect value. When I inspect the flattened string, the bytes appear to be out of order and some missing.
This behavior does not exist when I use a Single instead of Double datatype.
I have also tested this on a 9033 cRIO and My Computer targets and they function as expected.
Can anyone else confirm this incorrect behavior on an sbRIO 9637 or any other target?
Message 1 of 8
(4,370 Views)
The problem is that you are not converting it to an array, but to a scalar. Does it work better if you enable indexing at the output? Just curious.
(but yes, I agree there seems to be a bug because your code should work too)
Does the following workaround give the right value?
Message 2 of 8
(4,343 Views)
Your workaround is what I have already implemented as a temporary solution, I had disabled the indexing at the output of my for loop because I was just testing with one element. Turning indexing ON results in the same incorrect value.
Message 3 of 8
(4,340 Views)
Thanks. Good to know. I do have a sbRIO 9637, but I am working from home and it is in use, so I cannot test.
I assume that if the map contains multiple entries and you autoindex, all will be wrong, not just the first one(?)
I'll create an entry in the 2020 bug thread .
Message 4 of 8
(4,333 Views)
Correct, I was just trying to show the issue in its simplest form. Thanks for the help!
Message 5 of 8
(4,323 Views)
It also reproduces on a RaspberryPi 4; I'm guessing it's something unique to the arm architecture.
I'd be curious to see what happens if you try sending the result to the host via some other mechanism, such as a network published shared variable, network stream, etc. It's possible this is "just" a bug with how the interactive ui works and the target side code actually behaves as expected. (Neither of these are supported on a Pi, and I don't have any other arm targets handy,)
Edit: I just did a simple "equals" comparison (which should be valid in this case despite the fact it's a floating point), and the result comes back false. I think this is a legit case of incorrect code behavior.
Message 6 of 8
(4,225 Views)
One more observation... singles work fine but I64s are also wrong. I think it probably has to do with the fact it's a larger than 4 byte numeric datatype.
Also, for some inexplicable reason, an array of doubles (even a single element) seems to work fine.
Message 7 of 8
(4,219 Views)
We've seen this conversation and have reported this as bug #1131063 here at NI. Thanks for helping us make our product better!
C. Weeks
Product Support Engineer
NI
Message 8 of 8
(4,179 Views)
