regards to the case structure functioning.
My question is in regards to the case structure functioning.
The numeric value input to the case selector can only be an integer?
I wish to input a real number into the case selector, is this possible?
(1,526 Views)
You can input DBL as well, but it will get coerced to an integer so I would not do that. Your cases can be a range of integers as well, like "1..10". Do you have a specific example of what you need your cases to correspond to?
(1,515 Views)
that's okay thank you- I was just curious- I got a number of ideas how I can get around not having that...
thanks very much
(1,501 Views)
I'm not sure what you are trying to do, but remember that you should NEVER check equality with reals.
(1,492 Views)
