Is there a way to use log scaling with units?
Is there a way to set dBm as the units for a control? The base power unit used by Labview physical numbers is Watts, so I can use MW, nW, uW, etc. But we RF engineers tend to work in dBm, dBW, or dBV. This is really just another form of scaling.
David Grucza, CLD
(2,931 Views)
I assume you're referring to the unit label. Unfortunately, dBm is not a valid unit label. However, there's nothing stopping you from setting the caption for the control to "dBm" and simply interpreting the value of the control within your code as dBm. Smiley Wink
(2,920 Views)
That is what I'm doing, but setting the unit field takes care of automatic conversion to a set of base unit quantities that are placed on the wires carrying physical numbers. I'm creating a set of Labview classes and I would really like to incorporate this feature into them now. I'm hoping that if log scaling is not avaianble that NI adds it.
David Grucza, CLD
(2,916 Views)
You can submit your request to the Product Suggestion Center. I have no idea where this would fall in terms of priority for the next version of LabVIEW, though.
(2,903 Views)
I submitted it. It is likely a low priority, but should be very easy to do. I imagine the hard part is deciding how best to implement it. They could consider dBm to be a unit, or they could consider it to be a scaled, log scaling of a scaled unit (10 Bels re 10^-3W)
David Grucza, CLD
(2,900 Views)
