hidden function tool palette
Hello, I've just installed Labview 8.6 and I can't see the basics function in the tool palette.  How do I do to be able to see them?  When I do a seach, I can find them.
(2,836 Views)
This is from a fresh install? Weird. Did you install 8.6 into its own directory, or did you try to install it into a previous version's directory? You can try to reset the palette. Also, if you pin the palette (using the pushpin in the upper left) you can get a "View" menu and then go to the "Always visible categories" and select the categories you want to always see.
(2,826 Views)
Thank you, for a reason that I ignore, only a few categories were selected like addon, but not the basics function.  Weird, but now it ok.
Thank you for you quick answer.
(2,818 Views)
