Adding Array in FPGA
I noticed there isn't a add array elements in FPGA and was wondering how I can go about doing this task another way?  Looking for something wiht less overhead as well.  Any takers?  I tried using a for loop, index array, then run that index into an addition element, from the additioin element to a shift register, then the shift register into the other end of the add element.  This works for the first N (for loop interation), but after that, it just keeps climbing in values.  Any ideas?
guilio_2008
Message Edited by guilio_2008 on 09-16-2008 11:59 AM
(3,485 Views)
You cannot build a variable-sized array in LV FPGA; all arrays must be fixed sized.  See the help.
(3,482 Views)
Another option would be to use a memory or FIFO block which is configured with the expected maximum number of elements.
Depending on your use case you may use the one or the other
ThSa
(3,459 Views)
